Welcome to the Avid MediaCentral | Cloud UX Help > Working with Audio > The Audio Tab > Working with the Audio Tab in Source Mode
When you load an asset in Source mode in the Asset Editor, the Audio tab displays the audio tracks that are available for monitoring and lets you select which tracks to monitor. MediaCentral Cloud UX can load and monitor up to 24 audio tracks for master clips, subclips, and shotlists, five audio tracks for news sequences, and eight tracks for Sequences. You can adjust the volume for individual tracks or the overall volume. Adjustments are not saved.
The following illustration shows the Audio tab for a clip in Source mode and identifies the controls. The clip used in this example includes more than four tracks, with tracks 1 through 5 displayed. Other tracks are available by enlarging the tab or by using the scroll bar.
Control
Description
1
Panning knobs
Controls the panning for each track. In the current release, the panning buttons inactive for source assets. See Panning for Assets, Shotlists, and Sequences.
2
Solo and Mute buttons
Click the S (Solo) button to monitor only the selected track or tracks. All other tracks are muted. Click the M (mute) button to mute only the selected track or tracks. See Audio Monitoring.
3
Volume slider
When you hover your cursor over a volume slider, audio units appear to the right. You can click and drag the slider to adjust the volume level for an audio track. The level applies only to the selected track, not to the asset. Changes are not saved. See Audio Monitoring.
4
Volume level display and text box
Displays the level selected by the volume slider and allows you to type a level.
5
Track identifier
Displays the name of the audio track.
6
Scroll bar
Drag to view audio tracks that are not displayed.
7
Menu button
The Menu button includes an option to Use Current Audio Mute for Default. This feature allows you to define a new default muting configuration for your user account. For more information see Muting Audio Tracks.
8
Voice-over button
Click to open the voice-over controls. See Recording a Voice-Over.
9
Mix Mode button
Select Stereo or Mono to specify the audio output. See Setting the Audio Mix.
10
Audio meters
Displays the audio level for the mix of all tracks in the clip or sequence. There are two meters. For stereo output, each meter displays a separate level. For mono output, both meters display the same level. See Setting the Audio Mix.
You can change the reference level of audio monitoring in the User Settings. The default is -20dB. See Setting the Reference Level.
11
Master volume slider
Click and drag the slider to adjust the volume level for overall audio mix in the asset. Changes are not saved. See Audio Monitoring.
