Using a Sequence as a Source
You can open a Sequence in Source mode and use it as source media for another Sequence that is loaded in Record mode. You cannot edit a Sequence into a shotlist or a news sequence.
To edit material from a Sequence:
1. Locate the Sequence through the Browse app or the Search app, then do one of the following:
Drag the Sequence to the Media Viewer (Source mode).
Hold down the Control key (Windows) or the Command key (macOS) and double-click the Sequence.
The Sequence opens in Source mode in the Asset Editor.
2. Use the editing tools (Mark In, Mark Out, and so on) to edit the material you want into a loaded Sequence.
