Loading a Clip from the Sequence Timeline
You can load a media segment (video or audio) from a sequence into the Media Viewer.
This feature is similar to the Match Frame feature. However, Match Frame uses the location of the position indicator to determine which clip to load. The Load Clip feature loads the source clip for the segment you select, regardless of the location of the position indicator.
To load a clip from the Sequence Timeline, do one of the following:
Double-click the segment.
Right-click the segment and select Load Clip.
The source clip for the segment is loaded into Source mode in the Media Viewer. In and Out marks are set to match the segment used in the sequence.
