Welcome to the Avid MediaCentral | Cloud UX Help > Editing a Sequence > Editing a Sequence Associated with a Story > Saving a Sequence Associated with a Story
When you work with a sequence that is associated with a Newsroom Management story, be aware that changes are saved automatically in some cases, but manually in others. Review the following workflows to ensure that your work is saved:
• If both your sequence and your story include unsaved changes, the act of saving the sequence also saves the story automatically.
• If you have unsaved changes to a sequence and you attempt to load another sequence, you are prompted to save your changes before loading the new sequence.
For more information on saving a sequence, see Using the Save Button.
