Welcome to the Avid MediaCentral | Cloud UX Help > Working with the Log App > Working with Templates > Editing Components on Templates
The following table describes the different components you can add to a template and the controls they show when they are placed on the template.
Component
Description
Controls in the Visual Logging area
Free text: Used to enter text.
• Name text box
• Delete button
• Label text box (max. 100 characters)
• Down-arrow button to assign a shortcut
Buttons: Used to create a set of buttons, of which none, one, or more than one can be selected at the same time.
• Name text box
• Edit button
• Delete button
• Multi-selection check box
• Text editor to create button labels
Dropdown: Used to create a drop-down list from which one or more than one item can be selected.
• Name text box
• Edit button
• Delete button
• Text editor to create drop-down entries
Number: Used to enter a number, for example, the distance from the goal.
• Name text box
• Delete button
Rating: Used to select one through five stars.
• Name text box
• Delete button
Score: Used to enter the score of a game.
• Name text box
• Delete button
The following table describes the buttons you can use to edit the components on the template.
Button
Used by Component
Function
Buttons
Dropdown
Switches the editor from preview to edit mode and lets you add items, change item labels, and delete items from the button or drop-down component.
All
Removes the component from the Template.
When you remove a component from a session template the corresponding column is removed from the Text Logging area. You cannot delete a component that is in use by a span from a session template.
