Welcome to the Avid MediaCentral | Cloud UX Help > Publishing Assets > Publishing to Endpoints > Sending To: Facebook
The send to Facebook option enables users to send a text message with an associated media asset to authorized Facebook applications.
Each Facebook endpoint includes a character counter at the bottom of the tab. As you type your message, the character count decreases to give you an indication of how many more characters are allowed. The maximum number of characters for a Facebook post is 6000. If you enter more than 6000 characters, the counter turns red and displays a “Message too long” error.
To publish to Facebook:
1. If necessary, click the plus (+) button in the Send To menu to add a Facebook endpoint.
The endpoint appears as a new tab as illustrated below.
2. (Optional) Add a message to your Facebook post by entering text in the message field.
3. (Optional) Add an image to your post by using one of the methods described in Adding or Removing Media Assets.
*If you add an image file that does not meet Facebook’s format requirements, the Publish app displays an error message to inform you of the problem. For more information on supported formats, see: https://www.facebook.com/help/1703757313215897.
4. (Optional) Add an audio / video asset to your post by using one of the methods described in Adding or Removing Media Assets.
For more information on Facebook’s video requirements, see https://www.facebook.com/business/ads-guide/video/facebook-feed/video-views.
5. (Optional) Configure additional endpoints as needed.
6. Finally, click the Publish button in the Publish header to complete the process.
If you want to watch the progress of your Publish job, open the Process app for a status of all jobs submitted by the current user. For more information about the Process app, see Working with the Process App.
If your Publish job is successful, the information on your completed job is cleared from the Publish app, resetting all endpoints to their default configuration. If the job is not successful, the configuration information is maintained so that you can review and attempt the job again.
