Welcome to the Avid MediaCentral | Cloud UX Help > Using the Publisher App > Publisher App Overview > Publisher App User Interface > Editing Toolbar Enhancement Icons
Editing Toolbar Enhancement icons are used to enhance your video clip before publishing it.
The Editing Toolbar Enhancement icons are described in the table below:
Icon
Name / Keyboard Shortcut
Description
Select Preroll
Enables you to add or change the preroll for your video.
For more information, see Adding Pre and Post Roll.
Add Video Transition (to Preroll)
Enables you to add a video transition to your preroll.
Add Audio Transition (to Preroll)
Enables you to add an audio transition to your preroll.
Dynamic Overlay
Enables you to add a dynamic overlay to your video clip. Once selected, you can edit certain characteristics of how it appears within the clip.
For more information, see Adding Dynamic Overlay.
Text Overlay
Enables you to add a text overlay to your video clip. Once selected, you can edit certain characteristics of how it appears within the clip.
For more information, see Adding Text Overlay.
Image Overlay
Enables you to add an image overlay to your video clip. Once selected, you can edit certain characteristics of how it appears within the clip.
For more information, see Adding Image Overlays.
Edit 1:1
Enables you to edit the clip in 1:1 aspect ratio.
For more information, see Editing 1:1 Video.
Edit 9:16
Enables you to edit the clip in 9:16 aspect ratio.
For more information, see Editing 9:16 Video.
Edit Subtitles
Enables you to add subtitles to video clips.
Add Exclusions
Enables you to designate one or more segments to be excluded from the video clip.
Add Video Transition (to Postroll)
Enables you to add a video transition to your postroll.
Add Audio Transition (to Postroll)
Enables you to add a audio transitions to your postroll.
Select Postroll
Enables you to add or change the postroll for your video.
Timecode
Displays the timecode of the currently loaded clip.
Apply a Template
Enables you to select a pre-defined template from the list.
Download the Clip (MP4)
Enables you to download the currently loaded clip as an MP4 file to the location as set in your Browser for saving downloads.
Download Subtitles
Enables you to download the subtitles contained in your clip. These subtitles are downloaded to the location as set in your Browser for saving downloads.
Clone
Brings up a menu that depending on what type of media you have displayed, presents the following options:
Clone - Creates a copy of the media and enables you to save it to your local profile as the same format in which it is currently (video, image, GIF) in the Clips Management tab.
Clone as video - Creates a copy of the media and enables you to save it to your local profile as a video in the Clips Management tab.
Clone as image - Creates an image of your video and enables you to save it to your local profile in the Clips Management tab.
Clone as GIF - Creates a GIF of your video and enables you to save it to your local profile in the Clips Management tab.
Copy link to clipboard - Enables you to copy a link to your clipboard.
Assign to profile - Enables you to select which profile this clip or image will be associated with.
For more information, see Cloning a Video or Image.
