Welcome to the Avid MediaCentral | Cloud UX Help > Working with Audio > Setting the Audio Mix
You can set the audio mix as mono or stereo, in the Asset Editor, either Source mode or Record mode. The audio mix is used for monitoring only and is not saved with the asset. For more information, see Audio Monitoring.
To set the audio mix:
*Click the Mix Mode button to select Mono.
MediaCentral Cloud UX maps all audio tracks to a center pan, which creates a mono mixdown of all tracks. It outputs the resulting track to two identical channels.
*Click the MixMode button to select Stereo.
MediaCentral Cloud UX maps all audio tracks to two channels. The mix depends on your panning settings. See Panning for Assets, Shotlists, and Sequences and Panning for News Sequences.
