Deleting Components from a Template
You can delete a component from a master template at any time. Note that you cannot delete a component that is in use by a span on a session template. For those components, a warning message is shown after you click the Delete button and the component is not deleted.
To delete a component from a template:
1. Click the Delete button of the component in the Visual Logging area.
A security prompt opens.
2. Click Delete.
The component is removed from the template. The remaining components are moved and resized to fill the space.
