Welcome to the Avid MediaCentral | Cloud UX Help > Editing a Sequence > Working with Sequences > Trimming Segments in the Timeline
You can trim a segment from either end, lengthening or shortening the segment frame-by-frame or by larger increments. You can also perform a dual-roller trim, in which the combined duration of both segments remains the same.
After you trim a segment, the position indicator automatically moves to the new position in the sequence and the frame at that position is displayed in the viewer of the Asset Editor so you can see the exact frame to which the segment was trimmed.
*You can only lengthen a segment to the maximum length of its original source media.
The following topics describe trimming segments:
• Trimming a Shotlist (Single-Sided)
• Trimming a Sequence (Single-Sided)
• Trimming a News Sequence (Single-Sided)
• Trimming from the Top or the Tail of a Segment
• Using Dual-Roller Trim
