Welcome to the Avid MediaCentral | Cloud UX Help > Using the Publisher App > Publisher App Overview > Publisher App User Interface
In addition to the initial interface where you can add content and browse for files, templates, and decorators, the Publisher app contains a different user interface with five main areas that enable you to edit the content that you have added.
The following table provides more information on each of these areas.
Section
Description
1
Publisher app Header
The Publisher app Header includes an area where you can drag and drop your video assets (clips) that you want to use to initiate your Publish job.
For more information, see Publisher App Header.
2
Editing Toolbar
The Editing Toolbar includes Enhancement Icons that allow you enhance Video Clips with Preroll and Postroll, Text and Graphic overlays, among other things.
For more information, see the following:
3
Video Playback Window
This is where you can play the clip. As you play the clip, you can change the In and Out points, the Fit, and aspect ratio using the controls below the video.
For more information, see Video Playback Window.
4
Publish Sequence Timeline
If a video clip has been loaded into the Video Playback Window, the Publish Sequence Timeline allows users to edit the clip prior to the final publish.
For more information, see Publish Sequence Timeline.
5
Clip Details Area
Displays selected assets and associated metadata.
For more information, see Clip Details Area.
The Publisher app can be docked for greater productivity and streamlined workflows.
If you want to use multiple apps simultaneously, open a core app, dock it, and then open the Publisher app.
For more information on app types and how to dock them, see the following topics:
• App Types
• Docking Apps.
